Remote Networking
VIA installation problem Win7/32Bit
Hi i hope this is the right section for VIA questions.
We are currently installing a Aruba network in to our new building.
But we are running a test on the equipment in the old first.
The problem that we have right now is with the VIA installer.
We have a few Client Computers there it Rollbacks during the installer.
All systems are HP 2540p With Windows 7 Pro 32bit.
We have deactivate Kaspersky and any other system that can protect Register and File system.
The last thing i can see in the "status field" before it Rollbacks is "creating Icon and shortcuts"
The last Lines form the MSI Installer log:
Property(S): SourcedirProduct = {E9B25B84-16DD-4B71-ABA4-DBC3D4CDB0FA}
Property(S): ProductToBeRegistered = 1
Action ended 12:44:47: ExecuteAction. Return value 3.
Action 12:44:47: FatalError.
Action start 12:44:47: FatalError.
Action 12:44:47: FatalError. Dialog created
Do anybody have a hint on what can be wrong?
Thankful for any pointers I can get.
Re: VIA installation problem Win7/32Bit
What version of ArubaOS?
Sry here are the Version on Aruba and VIA.
ArubaOS 5.0.2.0
VIA Client Version: 1.0.0.24787
And thanks for quick respons.
svrbjgu, Windows 7 is not officially supported. Please open a case with tac so that they can take a look at the logs.
MVP
What OS's are supported?
I read (from an old post) win7 64bit isn't supported, and now (a not so old) post stating 32bit isn't either?
Does explain why I couldn't get VIA working on my laptop but seriously.. no win7 support at all? :eek:
Koen (ACMX #351 | ACDX #547 | ACCP)
As of ArubaOS 6 Windows 7 32-bit is supported.
MVP
that means (1) we cannot install the client on 64bit systems or just that (2) there is no native 64bit client but we can install the 32bit one and get it working?
32-bit - Good. 64-Bit.... Not there yet.
MVP
I just got an update from my Product management Team regarding the via 64 bit. At this time the 64-bit VIA client cannot be distributed from the controller’s internal web server due to flash size limitations. The 64-bit version of VIA for Windows v1.2 has been released and is available for download from the support website. Customers who want to distribute this client to their users must do so through an external web server or by pushing out the .msi file using desktop management systems. Beginning with AOS 6.1, we’ll again be able to host both 32-bit and 64-bit client versions on the controller.
Kindly try the same and let me know whether you are able to download and work fine.
Installed and working on my win7 - 64bit system.
So 64bit and what version of AOS
Just to clarify... you need at least 6.0 code to run or support the 64bit client?
