Contributor II
Via
Hi
Im trying to configure VIA on our aruba RAP-5. I found a guide but it is for aruba v5.0 but im running v6.1.2.2.
Im also not able to find the installation file for the clients on arubas website
thanks
/carlos
Re: Via
Hi
thanks
/carlos
Carlos,
VIA is configured on the controller, not the RAP-5.
You can find the VIA client downloads on the controller http://yourcontroller/via or by visiting the downloads section of the Aruba Networks Support site.
Zach
Zach Jennings
Contributor II
Re: Via
thanks for the download link but do u have any guide for the VIA configuration?
Via
Check the User Guide for 6.x. There are configuration instructions in there. "Chapter 15: Virtual Internet Access"
Zach
Zach Jennings
Re: Via
Carlos - the best place to get this info is from the ArubaOS users guide. The 6.1 guide is here: http://support.arubanetworks.com/DOCUMENTATION/tabid/77/DMXModule/512/Command/Core_Download/Default.aspx?EntryId=5926, but you will have to have a support login to download it.
