Weird VIA Issue
Hi All,
I have VIA Setup on a 620 Controller for a couple of machines to VPN in.
Got it all connected fine, double checked the policy is allow-all
But when I first connect it can take up to 3 mins before I can ping any thing on the network and then it keeps coming and going. Also the Link to the VPN drops out.
I checked the switch configuration and that's fine. I don't know what else it could be.
Re: Weird VIA Issue
Please initiate the connection from inside your network to rule out the internet portion of this.
Colin Joseph
Aruba Customer Engineering
Re: Weird VIA Issue
I think its narrowed down to my laptop, losing its wireless card for some random reason. I tried it on another machine and it seemed to work fine. I will investigate further.
