Remote Networking
What is the "Device Identifier" for the Huawei E1550 3G?
Contact Support
Please contact support. Do not see a previous configuration for that device.
Re: What is the "Device Identifier" for the Huawei E1550 3G?
You can search for device id in linux forums as it is used to configure usb parameters in different linux distributions.
I did not test E1550 before and I would suggest you to use one of the supported modems, but you can try --vendor id 0x12d1 --product id 0x1446, so device id is 0x12d11446. I found these values posted in other linux forums.
Please let us know if this works.
Thanks a lot Ahmed,
also i need the "USB Serial", do you know how to get it?
Look I was able to get the Hardware ID "0x12d11001" from the driver properties in device manager
pto
Contributor I
show ap debug usb ip-addr
