Remote Networking
Wireless printers for single user offices
Hi, I'm after product advice! I'm after a low to mid-rage wireless laser printer (mono only). Ideal we want the printer to connect using WPA and RADIUS but I can't find any printers (that don't cost a fortune) the use RADIUS
Any ideas?
We could wire it to the E1 port but as the printers will have to do directory lookups for scanning and faxing we would rather not open any security loop holes if possible.
