Remote Networking
Contributor I
step by step guide on how to set up an Aruba Remote Mesh
Our institute has a number of guest apartments in different buildings. Even if being in one building, these apartments are not necessarily located next to each other and therefore installing network cables was no option. So the aim was to have one DSL line per building and cover all guest apartments by using Aruba's Remote Mesh capabilities.
It took me some days to figure out how this has to be configured. Neither the ArubaOS 5.0 User Guide nor the knowledge base document 1052 did provide information detailed enough. Also, the steps in the ArubaOS 5.0 User Guide are somehow in a strange order. We also had a discussion at AirHeads Online: https://airheads.arubanetworks.com/vBulletin/showthread.php?t=2667
In this document, I've written down all configuration steps I had to do in order to get a working Remote Mesh in our test environment. It proved to work when doing the same steps on our production controller. I hope other Aruba users will find this helpful.
Dirk
Re: step by step guide on how to set up an Aruba Remote Mesh
Nice step-by-step guide, Dirk! Good job. I'll try this config whenever I have a moment to do it.
Thanks so much!
Jorge
Dirk
Dirk,
Thanks so much for this step-by-step!
