Remote Networking
Frequent Contributor II
usb 760 modem by Verizon setup?
Has anyone setup a Verizon USB 760 modem on a ap70 setup as a RAP? Verizon tells me it's the same as a usb 727 but it's not working with the 720 settings.
Also found this (http://airheads.arubanetworks.com/vBulletin/showthread.php?t=1853&highlight=modem) but the settings don't seems to work either.
David Dipert
Settings
Did you look down later in the thread to see what was done? He got it working.
Re: usb 760 modem by Verizon setup?
After going through the below steps for a 2nd time we were able to get the USB760 working.
First go to the Verizon Wireless Manager on a Windows machine. Plug the WWAN device into the computer, wait till it is recognized, confirm that it works by connecting to VZ WWAN, disconnect, go to Options / Preferences / Click on WWAN and uncheck the boxes for "Enable Removable Disk" and Enable VZAccess Manager" CD-ROM Disk. Click OK and wait for the settings to apply. Remove the Card, plug it into the AP and provision it according.
David Dipert
