Remote Networking
via: remote server connection failled
hello,
i want to use VIA clients. I configured everything that's needed including
l3-auth/via auth.profile/server groep: radius server
We are already using this radius server for our laptops using our AP's in the building. So the radius server is configured OK.
When i want to connect with a VIA client, i get the error: remote server connection failled
Any ideas?
W're using aruba OS 5.0.2.1. I tried VIA client 32 bits (version 1.0.0.25217) and VIA client 64 bits (version 1.2.0.26384).
Jan Roelof
Re: via: remote server connection failled
Enable debug logging:
logging level debugging security subcat ike
logging level debugging security process aaa
logging level debugging security process authmgr
logging level debugging security process l2tp
show log security 50
