Security, WIDS/WIPS and Aruba ECS
Occasional Contributor I
Blacklist users on bridged SSID
I'm having a little trouble with blacklisting a wireless client and I wanted to check if blacklisting works on bridged APs.
We have a bridged SSID available on a remote AP. I currently have an access control list applied to the user role for the virtual AP profile.
One of the rules in the ACL is that any traffic to our internal servers is dropped and the user/device should be blacklisted.
I can see a user device sending packets that breach the ACL rule. The packets are dropped, but the user isn't blacklisted.
The Aruba controller is running version 5.0.3.3.
L
Re: Blacklist users on bridged SSID
That should work. We might have seen an issue recently where this does not work correctly. Please open a case with Aruba TAC so that your individual case so we can replicate your issue with your setup.
Thanks Colin.
I've opened a case with TAC.
Regards
L
