Security, WIDS/WIPS and Aruba ECS
Captive Portal for Guests Not Working
the captive portal for our San Antonio office is not working properly. Right now, any guest can log onto the guest network without being prompted for a username and password. It is set up the same as our Dallas controller which works fine. When I compare the configuration, everything looks perfect. Is there something I could be missing?
Re: Captive Portal for Guests Not Working
Hi Scott,
Are you sure the initial roles are the same, and the CP profiles are all there? My guess is the initial role is set to authenticated or guest, not to logon. Posting partial configs will probably help us out on this.
thanks,
-awl
Andy Logan, ACDX
Director, Strategic Account Solutions
Aruba Networks
Scott,
As Andy said, it is probably due to the initial role in the AAA profile allowing traffic that should be redirected to the CP. For instance, if you are using "guest" as the initial role, then anyone that connects will be allowed to get an IP address, resolve DNS and browse the Web (tcp/80 and tcp/443) without any authentication. If the initial role is "authenticated", all packets are allowed before authentication. The initial role should probably be "guest-logon". That role allows DHCP and DNS, but if any tcp/80 or tcp/443 packets are sent, they are redirected to the CP.
See what AAA profile you are using under the VAP that houses the guest SSID and verify the initial role. If it is not correct, go into the AAA profile (Configuration > Authentication > AAA profiles) and change it to guest-logon.
Occasional Contributor I
What os are you running? I had this same issue and it made CRAZY for about a week. I finally called support and turns out that I was running a version of code that killed the CP and the webserver. Nice testing aruba! I think that was version 5.0.1
Imagine...
If you opened a support case the first day.....
Now you sound like my boss. You learn nothing if you call for help everytime something MIGHT be wrong. How many times have you done something and it did not work and turns out it was your fault? Or some setting you missed or set wrong? I am not going through the pain of dealing with India if its something simple that I missed. This time it turned out to not be my fault and I was gonig to make sure of that.
Now if aruba support was in america and I could understand them maybe my thought process would be different.
My bet....
Is still on 1st level TAC the first day, because they know about all the Zero-Day issues that can save you considerable amounts of time...
