Security, WIDS/WIPS and Aruba ECS
Controller and Trust CA
Can Aruba apply one trust cert to many controller ??
And how different of Certificate Type
-Trusted CA
-Server Cert
-Public CA
Thank you,
Re: Controller and Trust CA
Not at the same time. It must be done individually to each server.
I create captive portal profile that redirect login page to external server.
I upload trust cert from CA (Thawte) into controller with PEM file format and Server Cert format type. Then I apply this server cert in captive portal profile.
But when I open web browser for login to the system, all of web browser detect untrust cert. How wrong with it ?
What certificate authority is the browser saying? Thawte? That means that your client does not trust Thawte.
