Security, WIDS/WIPS and Aruba ECS
Frequent Contributor I
Device Identification Fingerprint
i want to ask if anybody has tested the Feature Device Identifivcation Fingerprint to distribute different User Roles within one PSK SSID. If yes, i would be glad to get an short description how to implement it.
Thank you and best Regards
Re: Device Identification Fingerprint
First you create a PSK SSID, through the WLAN/LAN wizard, or how you would normally do it.
Next, you add a user derivation role to the AAA profile that is created using the article here: http://airheads.arubanetworks.com/vBulletin/showthread.php?t=3469
Thank you for that Links
Best Regards
