Security, WIDS/WIPS and Aruba ECS
Tipping Point IPS problem - inspecting GRE traffic?
Does anyone have a Tipping Point IPS in between their controller and APs? We are having a problem with the IPS inspecting the packets and causes a large amount of latency. We've tested on a switch that doesn't go through the IPS and it works fine however if we put that access point on a switch that hits the IPS and then the controller we get terrible performance. We have also singled out the IPS by putting it into layer 2 failover and the performance returns to a normal/expected level and after bringing the IPS back into service the performance is terrible again. We are thinking that the IPS is inspecting the GRE packets because they look suspect but doesn't block them.
Does anyone that have a rule or policy to avoid this or knows which policy to modify? Any help would be appreciated.
Thanks!
Tipping Point
Thanks!
Bill, I am not familiar with Tipping Point, but I will quote someone who is:
"I would agree that this would be an issue. The TippingPoint IPS
does not understand the data that is passing
thru it. It does have the ability to inspect traffic inside a GRE tunnel,
but it would not be able to break the client to controller encryption so all
packets would have to hit the slow path before it can pass the traffic. The
CPU on the TippingPoint must be pegged because the slow path eats up a ton
of resources on the device.
I would recommend that they either bypass the IPS for the traffic between
the AP's and controller or if they can not I would make sure that they
included a rule / filter that allows all GRE tunnel traffic to pass
uninspected to the Aruba Controller."
ArubaOS 8.3 User Guide
InstantOS 8.3 User Guide
Airheads Knowledgebase
