Security, WIDS/WIPS and Aruba ECS
Valid Client Not Using Encryption
I recently upgraded my controller to 6.0.1.3, and have since noticed regular security logs for "Valid Client Not Using Encryption". Looking around I haven't noticed any configuration issues that stick out at me.
Here is the log message:
"Valid Client Not Using Encryption: An AP detected an unencrypted frame between a valid client ( ) and access point (BSSID ), with source and receiver . SNR value is 35."
Just wondering if anyone had any ideas on what could be causing this. Doesn't seem to be any specific clients, it has happened on Windows boxes and phones.
Thank You
Re: Valid Client Not Using Encryption
If a device connects to your network with encryption, it is recorded as a "Valid" client. If it connects to anything within earshot of your network (or even your network) without encryption, you will see that message.
The networks that clients are connecting to are either WPA2-PSK-AES or WPA2-enterprise-AES. So why would they be throwing this error.
Aruba SSID Profile:
wlan ssid-profile "XXXX-ssid_prof"
essid "XXXX"
opmode wpa2-aes
ht-ssid-profile "XXXX-htssid_prof"
The question is, what is the BSSID in the message and what access point does it correspond to?
The BSSIDs in the messages are for both AP's in my Aruba network which is WPA2-Enterprise-AES, and a linksys that is configured with WPA2-PSK-AES.
That should not be. Please open a TAC case so they can get to the bottom of it.
