Security, WIDS/WIPS and Aruba ECS
Occasional Contributor I
Wireless VLAN hopping
Hi -
Does anyone know if wireless VLAN hopping is feasible or has seen a PoC in the real world?
In wired environments, clients can doubly tag frames. One with the correct VLAN, and one with the target "hopped" VLAN. When the switch processes the correct VLAN, it strips the information, leaving only the target VLAN. Then the client is able to 'hop' onto the target VLAN.
In another scenario, the client is able to spoof a switch that supports trunking and is able to send frames to the target VLAN to be processed by the upstream switch.
Is this technically feasible given the different layer 2 characteristics of Ethernet and wireless? Also, if the option "Preserve Client VLAN" is enabled on the virtual AP profile, could you be opening yourself up to this type of attack?
Re: Wireless VLAN hopping
We have not seen this on wireless.
Colin Joseph
Aruba Customer Engineering
