Hi All
We have a requirement wherby we want to have 2 guest networks on our controller, they will both use the local database for authentication.
Is it possible to stop the client being able to connect to both SSID's ? as it shares the same local database.
cheers
Carl
No, using controller you cant do this.
But you can put them in denyall role.
Like SSID-A : user1 [guest] user2 [denyall]
SSID-B : user2 [guest] user1 [denyall]
