Frequent Contributor I
3600 routing over multiple interface ports
Trying to configure a new interface port back to my core swtiches and have a new SSID's subnet/VLAN over that new interface. Default route is over existing interface port. How can I make it that anything sourced by new SSID subnet/VLAN route over new interface port?
Tony Marques
Re: 3600 routing over multiple interface ports
You don't need to route.
Create the VLAN on the controller and add it to the new uplink to the core switch. Assign the users to that VLAN in the Virtual AP profile.
Let the core switch be the default gateway.
