(6.0.2.X to 6.1.X) Installing CPPM-x86_64-6.1.0.50820-upgrade.bin ... ERROR - Upgrade failed
Hi Guys,
i have an issue, Im trying to upgrade my CPPM from version - ClearPass Policy Manager 6.0.2.52212 on CP-SW-VA platform to version 6.1.
I followed all the instrucecions in the following pdf - Tech_Note_Installing_CPPM6_1_VM
But i keep getting an ERROR:
please advise.
some screenshots:
Thanks in advance.
Me
Re: (6.0.2.X to 6.1.X) Installing CPPM-x86_64-6.1.0.50820-upgrade.bin ... ERROR - Upgrade failed
Kdisc98,
Please use the method I suggested before.  The Upgrade package erroneously shows up as available on an evaluation VM,  and it even lets you try, but it cannot be installed.
ok doky
just finished the creation of a new 6.1 machine + importing of the old backups - everything working fine - thank u all!
