Occasional Contributor I
6.3.4.6 issue having role add after Authentication
Hi everyone
Is anyone having problem with role not being added after Authenticating in 6.3.4.6. It was working fine till I upgraded now I can not login to cppm or authenticating using 802.x1 with AD credential. Anyone else have a issue after upgrading?
Raul Bracamontes
LEUSD
Re: 6.3.4.6 issue having role add after Authentication
Can you login with the admin account and look at access tracker to see what's happening?
Tim Cappalli | Aruba Security TME
Thanks for Responding Cappalli.
I am getting this.
Service Name :
AD auth for CPPM ClearPass Admin Access (Active Directory)
Authentication Source :
AD Authentication
Role:
 [User Authenticated], [Other]
Profiles:
[TACACS Deny Profile]
The [other]  Role should be TACACS Helpdesk
Session ID:
T00000013-01-53c462e7
Time:
Jul 14, 2014 16:08:23 PDT
Status:
AUTHEN_STATUS_FAIL
Request Type :
TACACS_AUTHENTICATION
Message:
Client IP :
127.0.0.1:
Error Category:
Tacacs authentication
Error Code:
Authentication privilege level mismatch
 Alerts for this Request :
Tacacs serverRequested priv_level=[01] greater than Max Allowed priv_level=[00]
 Authorization Requests Messages
Contributor I
Check the privilege level in the enforcement profile, you will need to change the MAX level to 1 not 0.
They have 1
Contributor I
Have you defined the tips role Other in the enforcement policy?
It was working before I did the update.
Aruba
Please make sure you have a TAC case open. Its looks like you might have had a file that did not migrate correctly. It might be as simple as importing an updated dictionary file or TAC may need to login as root.
Thank You,
Troy
Contributor I
What was the outcome on this problem?  I am doing a fresh install and have followed the documentation about setting up TACACS and I either get the default read only admin or if I get away from using roles and just enforcement policy I get the same "Requested priv_level=[01] greater than Max Allowed priv_level=[00]" Error.
Aruba Partner Ambassador ACMX #252, ACDX #824,ACCP, ACSA, AWMP, CCNP Wireless & Security
