Aruba
6.5 Onguard Tech Note
Ok guys long awaited OnGuard Tech note is now posted. Big kudo to Dennis for getting this done.
The ClearPass 6.5 OnGuard Configuration Tech Note has been posted. It covers the configuration steps for a basic OnGuard deployment.
 The document is available on the support site  http://support.arubanetworks.com/Documentation/tabid/77/DMXModule/512/Default.aspx?EntryId=7961
Direct link  https://support.arubanetworks.com/Documentation/tabid/77/DMXModule/512/Command/Core_Download/Default.aspx?EntryId=18043
Thank You,
Troy
Frequent Contributor I
Re: 6.5 Onguard Tech Note
Are there any Tech Notes similar to this but for OnGuard/VIA VPN connection through Aruba controller?
Not today, unfortunately.
Tim Cappalli | Aruba Security TME
