Frequent Contributor I
802.1X EAP-TLS with Mitel VoIP
Hi all,
I am trying to help a customer in getting their Mitel 6900 Series VoIP phones move to 802.1X using EAP-TLS. While CPPM part in configuring service and the rest is under control, I was wondering if anyone has dealt with this in real life deployment, as I would like to know:
a) where from did you push certs on phones (Mitel Admin Guide is mentioning "The phone downloads certificates using the URLs provided in startup.cfg file" without saying which server URL is pointing to)
b) how is the solution incorporated with AD/CPPM
I am sure there is a nice document somewhere explaining all of this, but I cannot find it :-). Thanks.
NesaM --ACMP, ACCP--
