802.1X machine authentication issue
Dear all,
il my network i have two ssid
1.- ssid : employees
                -machine authtication + user authentication
2.- ssid : directors
                - user autentication only.
the authentication of the first ssid is perfect
And I'm using only one NPS server for the two, the problem is that users from employee group with only "machine authentication" can access to the directors SSID , and they get the 802.1X authenticated role.
how can i do to fix that
Raouf CHAHBOUNE
ICT Network & Security Engineer
CCNP R/S | CCNA Security | ACMP|ACCP|ACDX
[If my post is helpful please give kudos, or mark as solved if it answers your post.]
Re: 802.1X machine authentication issue
Unfortunately,
NPS does not understand when a device has both machine + user authenticated successfully.  You cannot enforce that state with NPS.
You have two choices:
1.  Use a different server like ClearPass Policy Manager that keep track of the user + machine authentication status
2.  Use "Enforce Machine Authentication" in the 802.1x profile of the Aruba Controller.  http://community.arubanetworks.com/t5/Controller-Based-WLANs/How-does-machine-authentication-work-on-the-Aruba-controller/ta-p/183440
Colin Joseph
Aruba Customer Engineering
First thank you for the answer.
but my problem is with the second profile, the first profile do both authentication (user and machine) and it work perfectly , but for the second i want to use user authentication only, but when I connect to this profile (second) it do machine authentication what is and the user get 802.1X authenticated role and it is innormal .
Raouf CHAHBOUNE
The client controls what type of authentication is attempted. If you only want a client to do user authentication, you need to configure that on the client.
Colin Joseph
the probleme is not in aruba controller,but in  windows , because windows take the only the first authentication , so to do both authentication , you have to change manualy authentication from user authentication to machine authentication and vice-versa.
thank you for you help
Raouf CHAHBOUNE
Yes. This is by design. If you are using machine authentication then device is joined the domain so the expectation is that you will use group policy to configure the network settings to use both machine and user.
Tim Cappalli | Aruba Security TME
in windows there is 4 choises
user or machine authentication
user authentication
guest authntication
and we have tray all of them
if you have any tutorial or how to please give it to me
Raouf CHAHBOUNE
For AD-joined devices., you would use user + machine.
MVP
rchahboune
If you select the "User or Machine authentication" this will be the login process for AD machines when configured as suggested above:
Windows boots into windows = "Machine Authenticated"
User then successfully logs in with his AD username/password = State moves to "User Authenticated"
With "Enforce Machine Authentication" on the Aruba Controller you will then land in the 802.1x default role for the AAA profile.
If just one of the authentications is successful, the role according to the .1x will trigger.
Check out page 251-253 of 6.4 User Guide.
Regards
John Solberg
-ACMX #316 :: ACCP :: ACSA
Aruba Partner Ambassador
Intelecom Group - Norway
Remember to Kudo if a post helped you! || Problem Solved? Click "Accept as Solution" in a post!
