Occasional Contributor I
802.1x Certificate Problem! Urgent
Hi
We configured 802.1x authentication and its work. But there is a problem. I enter username and password after coming certificate page. You see this page attached. I don't want to come this page. How can i remove this certificate?
Re: 802.1x Certificate Problem! Urgent
There are dozens of posts on this topic. This is a normal part of using PEAP. The only way to prevent this is to preconfigure clients either manually or using something like Quick connect, group policy or profile manager.
Tim
Tim Cappalli | Aruba Security
You cannot.
Phase 1 of 802.1x is the setting up of a TLS/SSL tunnel between the device and the RADIUS server. This requires that a certificate is trusted by the device. You will only see this once.
Your other alternative is to use the Standalone Quick-Connect app. This can configure the supplicant and install the RADIUS server certificate. Ask your local Aruba Networks SE about this.
Zach Jennings
Also, you should never use the factory certificate from the controller. You should request a new certificate from your public certificate provider.
Tim
