Contributor II
802.1x auth and non-domain joined devices
At this moment I configured 802.1x with a 2008 radius server to authenticate computers and users, which works fine. But non domain devices (like iPhones) can also authenticate to the wireless network as long as they provide a valid domain user account. Is there a way to configure this differently so users can only authenticate when theyre on a valid domain computer?
Re: 802.1x auth and non-domain joined devices
You have 3 options:
1)  Use enforce machine authentication in the controller
http://www.arubanetworks.com/techdocs/ArubaOS%206_3_1_Web_Help/Web_Help_Index.htm#ArubaFrameStyles/802.1x/Configuring_802_1x_Authe.htm?Highlight="machine authentication"
2) Utilize ClearPass Policy Manager for advanced device identity
3) Issue client certificates to domain devices via GPO and restrict connections to EAP-TLS.
Tim Cappalli | Aruba Security
Contributor II
Hi Tim, thanks for your fast respone :)
I enabeld Enforce Machine Authentication in the relevant 802.1x auth profile, but I can still connect my iPhone as long as i provide a valid domain account. Any thoughts?
Edit: seems like we cross posted :) I will read the link you provided!
Regular Contributor II
In windows nps creat one policy with machine only rule. and assigned that to the controller.
make sure that your req is hitting correct policy..
That won't always work because if a user authenticates on an AD-joined
machine, it will fail authentication.
Yeah that's right.
it'll enable machine authentication only. user auth will not work.
Super Contributor I
Hi Enveekaa,
I wrote a post about this issue a few months back:
http://community.arubanetworks.com/t5/AAA-NAC-Guest-Access-BYOD/How-to-Machine-AND-User-Authentication-in-Windows-with-Clearpass/m-p/208471/highlight/true#M15856
It's a more advanced config in Clearpass, but it allows you to do Computer and User auth at the same time.
Hope it helps!
-Mike
Contributor II
Thanks for all the info guys, I fixed it by enabling "Enforce Machine Authentication" and remove the user auth option from the radius server.
Edit: This isnt a workable situation tbh, I tested some more and if the Machine Auth expires (eg the laptop goes sleep) the user can't authenticate anymore and is denied network access.
I setup a Windows 2012 R2 NPS Server, this might provide me the options I require. Ill report back if I  have more info))
Going the cert route is probably your best bet.
Tim
Contributor II
I think I have a decent solution at the moment.
I created a policy on the NPS server thats only allows computers to authenticate and configured the wireless connection on the laptop to only attemp computer authentication.
In my first test I did not disable user auth in the 802.1x settings on the laptop, obviously this caused auth to fail as soon as the laptop would attemp user auth.
Does this implementation has any side effects im missing?
