802.1x issue
Hi ,
All of a sudden my 802.1x ssids stopped working. I tried creating new 802.1x ssid even tried to modify existing one. Checked all the policies, rule everything is correct. What could be the issue?
when I create an open ssid , it works fine on the same vlan . just the dot1x which does not work. Debug shows  APAE disconnect.
 I also see no session coming on the controller .
Please find the attached logs.
Test client MAC address: 78:61:7c:27:4a:c2
Re: 802.1x issue
Check connectivity to that server:
Authentication server request Timeout, username=saran userip= usermac=78:61:7c:27:4a:c2 servername= CPPM-TCS serverip= bssid=b4:5d:50:d5:a5:b1 apname=b4:5d:50:c5:5a:5a
APAE disconnect is an internal ageout of a client...
Colin Joseph
Aruba Customer Engineering
Re: 802.1x issue
Thanks for reply.
How come i am not able to see any session request on the controller, at least a session should show while exchanging probs with the access points?
