Contributor II
802.1x on IAP and Clearpass
Our customer wants to create 802.1x on Aruba IAP with an external radius "ClearPass". At the site we have one Domain controller for several companies and each company have an Organization Unit (OU) in the domain controller, example: OU="Company1" and OU="company2", what customer want is that he wants to create only 1 ESSID in the whole building, and in case the employee is in OU="Company1" he will be assigned an IP from VLAN 20  in case the employee is in OU="Company2" he will be assigned an IP from VLAN 30.
Please advise if this is doable?
I highly appreciate your support.
Frequent Contributor II
Re: 802.1x on IAP and Clearpass
Yes this is quite doable. Please refer to below post:
https://community.arubanetworks.com/t5/Security/active-directory-organisational-unit-with-clearpass/td-p/212441
JayBee
ACDX | ACCX| CCIE (RnS/SP,DC) | ACCP | ACMP | ACSA | ACMA | JNCIS | JNCIA
If the provided solution resolves your issue, please mark it as accepted solution to help others.
Contributor II
Hi Jaybee,
Thank you, so in that way I can configure different profiles and map them to different Active directory OUs?
Thats correct. You will configure a single enforcement policy out of these profiles and assing them to the ClearPass service.
JayBee
Contributor II
Thanks alot Jaybee
