Contributor I
802.1x troubleshooting filter ID
Hi
Can anyone tell me which log will show the filter id sent from a RADIUS server? If I view a user debug log I can see that the client is authenticated and is assigned a vlan via a server derived rule but I do not see the nitty gritty of which ID was sent. I need this as I am working with a separate server management team and I want to show them exactly what the controller receives.
Stewart
Re: 802.1x troubleshooting filter ID
Try this:
config t
logging level debugging security process authmgr
logging level debugging security subcat aaa
 Then type "show log security 50" to see the results.
Nov 6 04:59:18 :124105:  <DBUG> |authmgr|  MM: mac=70:56:81:b2:cc:15, state=5, name=employee, role=Byod-Authenticated, dev_type=OS X, ipv4=0.0.0.0, ipv6=0.0.0.0, new_rec=1.
Nov 6 04:59:18 :124004:  <DBUG> |authmgr|  AUTH GSM: USER uuid(0x6), mac(70:56:81:b2:cc:15), name(employee), role(Byod-Authenticated), devtype(OS X), wired(0), auth_type(4), auth_subtype(9), encrypt_type(10), conn_port(0)
Nov 6 04:59:18 :124234:  <DBUG> |authmgr|  Tx message to Sibyte, blocking with ack, Opcode = 17, msglen = 204 action = 1
Nov 6 04:59:18 :124004:  <DBUG> |authmgr|  vlan_alloc_update (vlan_alloc.c:140): Vlan Alloc  usage ; usage=10 vlan 1
Nov 6 04:59:18 :124004:  <DBUG> |authmgr|  AUTH GSM: DELETE MAC user 70:56:81:b2:cc:15
Nov 6 04:59:18 :124090:  <DBUG> |authmgr|  Free macuser 0x0x106a620c and user 0x0x10590e8c for mac 70:56:81:b2:cc:15.
Nov 6 04:59:18 :124004:  <DBUG> |authmgr|  AUTH GSM: USER DELETE uuid(0x6)
Nov 6 04:59:18 :121031:  <DBUG> |authmgr| |aaa| [rc_request.c:76] Find Request: id=10, srv=192.168.1.32, fd=78
Nov 6 04:59:18 :121031:  <DBUG> |authmgr| |aaa| [rc_request.c:82]  Current entry: srv=192.168.1.32, fd=78
Nov 6 04:59:18 :121031:  <DBUG> |authmgr| |aaa| [rc_request.c:37] Del Request: id=10, srv=192.168.1.32, fd=78
Nov 6 04:59:18 :121031:  <DBUG> |authmgr| |aaa| [rc_api.c:1029] Authentication Successful
Nov 6 04:59:18 :121031:  <DBUG> |authmgr| |aaa| [rc_api.c:1031] RADIUS RESPONSE ATTRIBUTES:
Nov 6 04:59:18 :121031:  <DBUG> |authmgr| |aaa| [rc_api.c:1046]  PW_RADIUS_ID: \012
Nov 6 04:59:18 :121031:  <DBUG> |authmgr| |aaa| [rc_api.c:1046]  Rad-Length: 20
Nov 6 04:59:18 :121031:  <DBUG> |authmgr| |aaa| [rc_api.c:1046]  PW_RADIUS_CODE: \005
Nov 6 04:59:18 :121031:  <DBUG> |authmgr| |aaa| [rc_api.c:1046]  PW_RAD_AUTHENTICATOR: \246\344t\273\364\305\003\020:|\227\351j\335Hi
Nov 6 04:59:18 :124003:  <INFO> |authmgr|  Authentication result=Authentication Successful(0), method=radius-accounting, server=cppm-192.168.1.32, user=70:56:81:b2:cc:15
Nov 6 04:59:18 :124004:  <DBUG> |authmgr|  Auth server 'cppm-192.168.1.32' response=0
Contributor I
Thanks for the quick reply. Worked great,
MVP
So I thought I understood the logging level stuff.. however.. it seems I don't.
What weirds me out is that with both those commands you mentioned I do get the required output (filter-id returned).
I figured one of those debugs should warrant the same output as well but this seems incorrect.
This is what I tried to figure out exactly what command gives me the returned radius attributes. Each attempt I cleared the user-table so a new auth was triggered.
configure terminal logging level debugging security process authmgr
configure terminal logging level debugging security subcat aaa
show log security all | include  Filter-Id
=> Filter-Id: test
configure terminal no logging level debugging security subcat aaa
=> NULL
configure terminal no logging level debugging security process authmgr
=> NULL
=> NULL
configure terminal logging level debugging security process authmgr subcat aaa
=> NULL configure terminal no logging level debugging security process authmgr subcat aaa configure terminal logging level debugging security process authmgr configure terminal logging level debugging security subcat aaa show log security all | include Filter-Id => Filter-Id: test
Not what I expected.
So can anyone explain why I'm getting more (diferent?) output when having both logging debug levels active at the same time as apposed to the 'sum' of both used seperately?
Koen (ACMX #351 | ACDX #547 | ACCP)
MVP
Anyone that can explain those results?
