802.1x wired initial login and computer policies
  • 1.  802.1x wired initial login and computer policies
    Posted Apr 03, 2016 10:26 AM
    I’m looking for some advise on something: how do companies that run 802.1x on an Active Directory domain handle initial logins out at the workstation?  It seems impossible if you don’t already have a profile.  It's a total chicken/egg problem.  We have on-boarding static ports in our helpdesk area, so we can handle things for a while… but we’ll want a solution for doing initial logins out and about.  Like if there's a desktop and we want a new user to login, we can't do that because it doesn't have access to the right networks until post-login.
    This exact issue is also causing havoc on computer policies that are intended to run right at login.
    thanks
  • 2.  RE: 802.1x wired initial login and computer policies
    Posted Apr 03, 2016 10:33 AM
    This is done with Windows machine authentication. The computer logs into the network with the computer account at the login screen.. Once a user logs in, it switches to the user's credentials.
    Sent from Nine<>
  • 3.  RE: 802.1x wired initial login and computer policies
    Posted Apr 03, 2016 10:34 AM
    If these are Windows domain workstations you can deploy a group policy to enable the Wired Auth Windows service and also to configure the wired profile to do Computer or User authentication .
    When you enable computer auth it allows you to do Machine authentication before the user login .
    What are you using for RADIUS ?
    Sent from Outlook for iPhone
  • 4.  RE: 802.1x wired initial login and computer policies
    Posted Apr 03, 2016 11:03 AM
    Ahhhh... okay.  That makes total sense.  I wonder how much I'd have to tweak my CPPM policy to allow machine auth.  I'll start doing some research.  Not sure if it can be added to my already working user-auth service or if it's a new service.
    My wired services looks like this ATM:
  • 5.  RE: 802.1x wired initial login and computer policies
  • 6.  RE: 802.1x wired initial login and computer policies
    Posted Apr 03, 2016 11:09 AM
    Just add tips role equals [Machine Authenticated] and your access policy.
    Sent from Nine<>
  • 7.  RE: 802.1x wired initial login and computer policies
    Posted Apr 03, 2016 11:22 AM
    I'm just a bit confused because the computer is sending it's MAC address and falling into my EAP-MD5 static-host-list rules.  I expected it to be sending the computer's name.
  • 8.  RE: 802.1x wired initial login and computer policies
    Posted Apr 03, 2016 11:24 AM
    Are you doing Mac bypass on your switch ?
  • 9.  RE: 802.1x wired initial login and computer policies
    You should separate those out into two services.
    Is the client configured correctly?
    Sent from Nine<>
  • 10.  RE: 802.1x wired initial login and computer policies
    Posted Apr 03, 2016 11:34 AM
    Yeah, totally.  I'll make it two services.  If machine-auth, let it into my "walled garden" VLAN that can just hit AD and ClearPass... allowing me to do "on-net" logins.  Then once it gets into Windows it should flip over to user-auth, at least that's my understanding of this all.  Not sure if I'd have to do a CoA?
    My switch 802.1x config looks like such:
    authenticator {
    authentication-profile-name ClearPass;
    interface {
    User-Access {
    supplicant multiple;
    transmit-period 5;
    mac-radius;
    reauthentication 600;
    server-timeout 3;
    maximum-requests 3;
    guest-vlan CP-INITIAL;
    server-fail use-cache;
  • 11.  RE: 802.1x wired initial login and computer policies
    Posted Apr 03, 2016 11:52 AM
    Are you doing Mac authentication for other devices ?
    I looks like you do "Mac-radius"
    The question is why is the MAC address in the SHL for your domain device ? What should happen is that once your device fails Mac auth it should switch to 802.1x or viceversa
    https://www.juniper.net/techpubs/en_US/release-independent/nce/information-products/pathway-pages/nce/nce-157-aruba-dot1x-mac-configuring.pdf
  • 12.  RE: 802.1x wired initial login and computer policies
    Posted Apr 03, 2016 11:57 AM
    Yes, it's how we do our phones.
  • 13.  RE: 802.1x wired initial login and computer policies
    Posted Apr 03, 2016 12:36 PM
    Follow the instructions on the link I posted earlier
  • 14.  RE: 802.1x wired initial login and computer policies
    Posted Apr 03, 2016 05:43 PM
    Odd.... CPPM enforcement looks perfect, it's getting a VLAN with machine auth, but it won't do anything.  Can't ping gateway.
    root@ZZZ-TR1-CAS-VC> show dot1x interface ge-2/0/23 detail
    ge-2/0/23.0
    Role: Authenticator
    Administrative state: Auto
    Supplicant mode: Multiple
    Number of retries: 3
    Quiet period: 60 seconds
    Transmit period: 5 seconds
    Mac Radius: Enabled
    Mac Radius Restrict: Disabled
    Reauthentication: Enabled
    Configured Reauthentication interval: 600 seconds
    Supplicant timeout: 30 seconds
    Server timeout: 3 seconds
    Maximum EAPOL requests: 3
    Guest VLAN member: not configured
    Number of connected supplicants: 1
    Supplicant: f8b156d2eZZZ, F8:B1:56:D2:EZ:ZZ
    Operational state: Authenticated
    Backend Authentication state: Idle
    Authentication method: Mac Radius
    Authenticated VLAN: CP-INITIAL
    Session Reauth interval: 600 seconds
    Reauthentication due in 580 seconds
  • 15.  RE: 802.1x wired initial login and computer policies
    Posted Apr 03, 2016 06:29 PM
    Can you use this command : run show dot1x interface
