Frequent Contributor II
ACL blocks UDP broadcast when specifying port
Hi.
I am setting up a ACL rule which says
SRC: any DST: any Service TCP / UDP *port* permit
This works as long as the server and client device communicates directly to each others IP address.
The server uses UDP broadcast on the specified port to discover devices. This does not work.
The client device "data-LED" shows some activity when the broadcast is sent, so it looks like the broadcast gets through.
The server never recieves the response tough.
if I change the ACL rule to say:
SRC: any DST: any Service: Any permit, the broadcast discovery works.
When I check the wireshark logs the only specified is the same port that I spesify in the rule.
Anyone know what might cause this?
Thanks!
-ACMX #352-
Remember to Kudo if a post helped you! || Problem Solved? Click "Accept as Solution" in a post!
Re: ACL blocks UDP broadcast when specifying port
Type "show acl hits" to see if your traffic is hitting the firewall policy.
ArubaOS 8.3 User Guide
InstantOS 8.3 User Guide
Airheads Knowledgebase
Thanks.
We just solved this case.
Turned out that the equipment that the customer was using is work in progress, so the documentation was not complete.
The broadcast was answered to the private/dynamic port that the broadcast was sent from. This way, the traffic was using a different destination port than what we defined in the acl. This was fixed so now everything works as expected :D
-ACMX #352-
Awesome.
