ALE and AOS 6.3 location-server-feed enable command does not exist??
CLI reference guide says that location-server-feed enable is needed in order to send RSSI information to an ALE.
That command does not seem to exist in 6.3.1.1?
Am I missing something?
Pasquale Monardo | Senior Network Solutions Consultant
ACDX #420 | ACCA
[If you found my post helpful, please give kudos!]
Re: ALE and AOS 6.3 location-server-feed enable command does not exist??
In 6.3.1.1 it was replaced by the command:
mgmt-server type ale primary-server <ip address> profile default-ale
Interesting because the 1.0API release notes for ALE mention that command plus the location feed command.
ALE Release notes for 1.1 have no mention of that command.
6.3 CLI guide mentions "mgmt-server type amp or xe|xc" but on 6.3.1.1 you only have
(dnoc-wlc-2.rdlab.dv) (config) #mgmt-server type ?
ale Analytics and Location Engine
amp AirWave Management Server
Do you happen to know how I can verify that my ALE is licensed, even with an 90-day EVAL license?
Pasquale
ACDX #420 | ACCA
