Contributor I
About Aruba ClearPass Guest configure ,Please Help me , Thanks!
I amm a  beginner of Aruba Network ,I want to configure Guest Network and Self-register , But I don't have this information;
Re: About Aruba ClearPass Guest configure ,Please Help me , Thanks!
Do you have an instant ap or a controller ?
Are you trying to use the internal captive portal or clearpass guest ?
Thank you
Victor Fabian
Lead Mobility Architect @WEI
Contributor I
I use a  (CPPM) Devices of clearpass Guest , it is OS 6.2;
The environment have a Wireless Controller and Wireless AP,I want to use CPPM for guest System,Implement employee registration;
Here you go:
http://community.arubanetworks.com/aruba/attachments/aruba/tkb@tkb/220/2/Aruba%20Wireless%20and%20ClearPass%206%20Integration%20Guide%20v1.3.pdf
Thank you
Victor Fabian
Contributor I
The First , Thank your help ! But I use a CISCO Wireless Controller, I don't know how to set some attributes, don't know whether there is such a test configuration;
Start here:  http://support.arubanetworks.com/DOCUMENTATION/tabid/77/DMXModule/512/Command/Core_Download/Default.aspx?EntryId=6454
This document above has the Cisco side of the configuration, but the Amigopod Configuration is deprecated and should be ignored.
The ClearPass Guest side should be taken from here:  http://support.arubanetworks.com/DOCUMENTATION/tabid/77/DMXModule/512/Command/Core_Download/Default.aspx?EntryId=11900
Contributor I
Today, I try to set up the Clearpass Guest; I have to do is visitor system, self-help registration login, CPPM OS is 6.2;
Aruba Clearpass Guide 6.2,Most of the time, I studied not very compact configuration;
1.CISCO Controller has been set up completed;( L3 authencaion ---captive Portal )
2. I try to set up NAS on CPPM
3.I try to set up Self-register configure (NAS, redirect page)
4.What do I have to do? authorization profile ?  Mac Authencation ?
5.I can successfully create account, But account is invalid,The default Policy I didn't move
Make sure you have COA enabled
Thank You,
Troy
