Access Tracker Monitoring from Publisher
Hi
Curenntly i have a clearpass cluster with one publisher and 4 subscriber.
as we know the access tracker and event view is stay in the subscriber. Let say i want to troubleshoot the client connectivity from access tracer but centralized from publisher, how can i do it?
pub-sub communication is using http. 'Port 80 is used to render System Monitor data from a remote node. Can be modified using the cluster-wide parameter “Performance Monitor Rendering Port”
thanks
Re: Access Tracker Monitoring from Publisher
In the publisher node, you can edit the filter of the Access Tracker and select the server or all servers, including subscriber nodes.Screen Shot 2018-04-04 at 11.46.06.png
Rafael del Cerro Flores
ACMP, ACCP, ACDX#324, ACCX#711
thanks,
thats means i can view the access tracer on the subscriber (other nodes) from publisher?
Ussually I don't configure it, but technically yes. I can't check it now. In the access tracker there's a column to show the server name, you could identify whats is the node that is doing these authentication.
thanks its worked perfectly
