Active Sessions Management - Reauthorize
I have found and option to Disconnect Guest user and Reauthorize Guest User. What does exactly Reauthorize Guest User? How it works? What kind of profile do I have to addiotionaly configure?
Thank you,
Vulpe
Re: Active Sessions Management - Reauthorize
Hi Vulpe,
Please check below guide
https://community.arubanetworks.com/aruba/attachments/aruba/SoftwareUserReferenceGuides/29/1/ClearPass_Guest_6.4_User_Guide.pdf
In page 33, it explain in detail, we need to configure Radius CoA.
Pavan
If my post address your query, give kudos:)
Pavan
If my post address your queries, give kudos and accept as solution!
It issues a change of authorization​.
Tim Cappalli | Aruba Security
thanks for you answer. I applied CoA profile, but I got a warning that it is incorrect profile. I applied the same profile to Disconnect option and it was working. Do you have any example of that profile for Reauthorize user?
Vulpe
Could you please share the screen shot.
pavan
Pavan
