MVP
Adding member to cluster from remote location
We are looking at adding a new member to our existing cluster.
The existing cluster is made up of two CPPM servers running version 6.4.5.71725. We intend to upgrade before adding the new subscriber.
The new subscriber will be from our office located in China. We have a direct VPN connection to this office with around 300ms response time.
I am just wondering if there are any challenges that we might face? Is there anything special we need to do to ensure the success of this new CPPM joining the existing cluster? Will the latency pose any major issues?
Thank you,
Cheers
Re: Adding member to cluster from remote location
It should be fine.  These are the ports that the cluster communicates on.
  • TCP Port 80 HTTP (Between Nodes)
  • UDP Port 123 NTP (Subscriber to publisher)
  • TCP Port 443 HTTPS (Bi-directional)
  • TCP Port 4231 NetWatch (Post Authentication module and the node where Insight is enabled)
  • TCP Port 5432 PostgreSQL for DB replication (Subscriber to publisher)
Seth R. Fiermonti
Consulting Systems Engineer - ACCX, ACDX, ACMX
Email: seth@hpe.com
If you found my post helpful, please give kudos
MVP
Thanks @SethFiermonti
Much appreciated.
Am I correct in assuming that the licensing still works the same with the CPPM clustering. Where all the licenses are shared amongt the individual CPPM servers? We will be purchasing a new CPPM license for the new subscriber, but will be sharing our current pool of Onboard and Guest licenses.
Trusted Contributor I
correct the base licenses are per unit, they are also related to the chosen unit, i.e. CP-500, 500 of them.
the other licenses are shared within the cluster.
MVP
Thanks @boneyard for the confirmation!
