drn
Adding printer to Guest wifi
Hi, we have a guest wifi that is authenticated through captive portal. I would like to add just a basic HP wireless printer into the guest WLAN to allow associates to print if required. How do i go about this so that it doesn't need to go through captive portal but everyone can see it ?
Re: Adding printer to Guest wifi
You'll want to utilize user derivation rules.
Tim
Tim Cappalli | Aruba Security
