Additional DATA interface for Clearpass VM
How is it possible to add an additional DATA interface on a Clearpass VM?
Re: Additional DATA interface for Clearpass VM
This is not possible.
Tim Cappalli | Aruba Security
But how to setup Clearpass if you use it f.e. for 802.1X Authentication over a Corporate VLAN and use Guest Portal in a separate VLAN with Internet-only access?
I usually create a static route to ClearPass.
You can also create a GRE or IPSEC tunnel from the controller to ClearPass.
I'm looking for a solution with IAP and Clearpass - so I guess the GRE/IPSEC solution wouldn't work. And the static route solution is quite ugly in my opinion...
