After changing a print template cant access guest_index.php anymore
Was busy setting up clearpass. Edit the print template and the from there cant access anything on the guest pass side. Even the deafult guest_index.php doesnt work anymore. Did the so called cluster restore command via CLI but doing the same. Anyone experienced this issue and perhaps know how to properly roll back.
Re: After changing a print template cant access guest_index.php anymore
Do you get redirected to login or the page just doesn't even come up ?
Thank you
Victor Fabian
Lead Mobility Architect @WEI
I do get redirected to the login page when i need to authenticate first. Once i submit nothing happends. It goes to the guest_index.php in the URL but its completely blank, cant access any other php pages on the guest side either.
What happens if you try accessing it from Policy Manager QUICK LINKs in the dashboard ?
Do you see anything in Access Tracker after to login ?
Thank you
Victor Fabian
Does the same.
Good morning.
I have got the same issue: the page appears blank?
Any update?
Thanks.
Regards.
Andrea
If you haven't done so already, please open a TAC case in parallel while you wait for an answer here. We can only guess exactly what you did, but TAC would have a better chance at recovering your setup.
Colin Joseph
Aruba Customer Engineering
Many thanks Joseph.
Regards.
Andrea
This is a bug. I need to update to version 6.6.
