Regular Contributor I
Aftter installin ClearPass Cumulative Patch 1 for 6.3.0 webui doesn't work properly,
I have two CPPM (ClearPass Policy Manager ) in HA.
This morning i have installed the ClearPass Cumulative Patch 1 for 6.3.0 that i have found in "Software Update" tab of the web-ui.
I have installed it only on member that was in down state.
The installing is completed correctly, without errors.
I have rebooted the CPPM and after the reboot the webui of it cannot be reached.
If i try to connect, on the browser appear the following message:
" ClearPass Policy Manager™ could not find the page you requested. Redirecting in 5 seconds... "
and continue to redirect me on the same page.
I have tried to connect with different browser and with different version of these.
and i have tried to reboot the CPPM, but without success.
Have you any ideas?
Thanks in advance.
Andrea
Re: Aftter installin ClearPass Cumulative Patch 1 for 6.3.0 webui doesn't work properly,
Wait about 10 minutes and then do a service restart all.
It should fix itself.
Tim Cappalli | Aruba Security
HI,
Thank you.
I have tried with "service restart all"  but unfortunelly the situation is the same.
Andrea
I would open a TAC case then. Most of these cases have resolved themselves with a service restart.
i have opened a case with TAC.
I will update you when this issue is solved.
Andrea
