Age-group based web/content filter – Guests
I have an interesting client requirement where we have to capture the guest’s age along with username/password in captive portal and serve the webcontent based on their age.
I have got both Cisco ISE and ClearPass guest servers. I have got Cisco WLCs in the setup.
I have got both Fortigate(webfilter) and Cisco ASA. How to implement this solution to serve content based on guest’s age?
Re: Age-group based web/content filter – Guests
The first problem with that is nobody will tell you what their age is or they will lie.  If the system does not have everyone's age already in there, your enforcement is reliant on everyone telling the truth, so this might not be too practical.
ArubaOS 8.3 User Guide
InstantOS 8.3 User Guide
Airheads Knowledgebase
The short answer is yes, you can do it, by returning a different role that has a different set of Web (APPRF) ACLs.  You cannot act on input that is entered into a form, however...  If all the users already had their age range somewhere in AD that could trigger a role that has the correct filtering.
