Contributor II
Air group using cppm
Hi ,
Is there any guideliness pdf available..regarding how to register apple Tvs and air print enabled printers and also shared access of this devices??
thanks
srikanth
Re: Air group using cppm
It's a bit dated, but check out this doc, specifically chapter 5:
http://support.arubanetworks.com/Documentation/tabid/77/DMXModule/512/Command/Core_Download/Default.aspx?EntryId=12399
Tim Cappalli | Aruba Security
srikanthsoogoor wrote:
Hi ,
thanks
srikanth
Airgroup in ClearPass Policy Manager 6.3 Adds new features and functionality and they are covered in the ClearPass Guest User Guide here:  http://support.arubanetworks.com/Documentation/tabid/77/DMXModule/512/Command/Core_Download/Default.aspx?EntryId=12830
