Version Information:
Clearpass: 6.5.0.71095
Controller: Aruba 7220, Software 6.3.1.14
Details:
I registered three AppleTV devices (see one configuration in image below)
I have manually associated them to both controllers using the options availabe in AirGroup Diagnostics. Both of my controllers appear to be configured properly based on the Config Status in CPPM Guest saying OK.
However, no AppleTVs show up when trying to use AirPlay. If I remove enforce CPPM Registration then all AppleTVs show up.
I ran the following command on the controllers:
show airgroup cppm entries
The results I get back are:
ClearPass Guest Device Registration Information
Device device-owner shared location-id AP-name shared location-id AP-FQLN shared location-id AP-group shared user-list shared role-list CPPM-Req CPPM-Resp
Num CPPM Entries:0
This leads me to believe that there is an issue with how I created the devices using clearpass guest.
In the end I would like to create all the AppleTVs on the IT side of the house (100 or so) and enable them to be used based on the vlan location or role in CPPM.
Can anyone offer the best document to look at to ensure the configuration is setup or offer some additional specific troubleshooting steps?
~Indigo
