Regular Contributor I
Airgroup help/questions
I'm trying to implement airgroup with CPPM for Apple TVs.  It appears that the default clearpass airgroup service is geared toward apple TVs being on student networks or .edu environments with mac auth.  My Apple TVs are located in conference rooms and are on the corporate network using PEAP (profile loaded onto apple tv).  Is it still possible to use CP to limit who can see an Apple TV when it's on a PEAP network by changing the airgroup service?
Re: Airgroup help/questions
The AirGroup service should not be touched.
It doesn't matter which SSID the device or user is connected to as long as AirGroup is enabled.
The device authentication itself would be handled just like a user.
You'll need to setup the AirGroup integration in ClearPass guest by adding the controllers. Then you'll have to register the AppleTVs under "Create New Device" and then Enforce AirGroup registration on the controller.
Tim Cappalli | Aruba Security
Thanks Tim, I have setup the integration between the controller and clearpass.  I set the device in clearpass to only be shared to a certain role. Now I do not see airplay as an option on my iOS device.
Please run:
show airgroup cppm entries
show airgroup policy-entries
ClearPass Guest Device Registration Information
Device             device-owner  shared location-id AP-name  shared location-id AP-FQLN  shared location-id AP-group  shared user-list  shared role-list  CPPM-Req  CPPM-Resp
18:ee:69:18:b9:07  N/A        authenticated     45        1
        Employee
Num CPPM Entries:1
The “show airgroup policy-entries” isn’t a valid command on my controller.
The “show airgroup policy-entries” isn’t a valid command on my controller.  I’m still running 6.3.x on my controller
Are you seeing AirGroup Authorization messages for the ATV MAC address?
Yes, I see them in the access tracker.
msales,
Did you do any airgroup configuration on the ClearPass Guest side?  If you have CPPM enforcement enabled, that configuration will supersede what you have configured on the controller side.
I add the controller under the airgroup settings in CP guest and also added the apple TV has a device
Matt Sales
Network Engineer II
Centra Health
434-200-5574
Electronic Privacy Notice. This e-mail, and any attachments, contains information that is, or may be, covered by electronic communications privacy laws, and is also confidential and proprietary in nature. If you are not the intended recipient, please be advised that you are legally prohibited from retaining, using, copying, distributing, or otherwise disclosing this information in any manner. Instead, please reply to the sender that you have received this communication in error, and then immediately delete it. Thank you in advance for your cooperation.
Do you have a screenshot for the configuration of that AppleTV in cppm?
