Frequent Contributor I
Airgroup - how works the control whom presents
Hi guys,
We are planning to use Chromecast in our auditorium.
I read about Airgroup but I didn't see how we control whom presents using Chromecast.
For example, we have an audience with 3 authorized presenters, how I control whom will present in each time?
Is it possible to control this via CLI without Clearpass?
I'm very confusing about this.
Re: Airgroup - how works the control whom presents
You would need ClearPass to do per-user authorization.
Tim Cappalli | Aruba Security
Ok. But, has Clearpass an interface to the final user to control the time of presenters?
Not specifically per user, no.
And how it works in real life?
Can someone authorized to access Chromecast  "invade" the presentation of other?
If you are registering devices, then only people or devices in specified locations can discover the device.
Tim
But, Airgroup doesn't work like Webex meeting that has 3 holes: Host, Presenter and Participant, and these roles can be changed in real time during the meeting. Am I right?
Correct, it's all done via registration.
Generally, if you give people permission to use the device, you still have
to be in the room to see the on-screen code.
Thank you Tim by the explanation.
