Airwave Top Usage
Hi all,
i have question, can we split usage of client use to internet and local on "top ten usage client Airwave"
thank you
Re: Airwave Top Usage
up,
up, up,
It cannot be done.  That view only reflects total traffic, not separated by destination.
noted sir
if we create report , can we do this ? separate the destination local and internet of client usage ?
You cannot do that.  The report only shows TOP destinations.  You cannot separate local and foreign destinations.
well noted sir.
