d.p
Contributor I
Allow IPSEC vpn client connectivity via wireless
Hello
We are running into an issue where ipsec vpn connecitvity isn't working on our guest wireless.  SSL VPN works as its 443 but anything ispec is blocked.  Do I need to allow that network service or is there an easier way?
Aruba
Re: Allow IPSEC vpn client connectivity via wireless
There is a predefined "vpnlogon" policy that permits all standard VPN protocols.    You could apply that to your guest role, or selectively add what you need.
The following summarizes the ACL:
ip access-list session vpnlogon
user any svc-ike permit
user any svc-esp permit
any any svc-l2tp permit
any any svc-pptp permit
any any svc-gre permit
user any svc-natt permit
AMFX | ACCX | ACDX | ACMX
