hyc
Allow WiFi usage when externally hosted splash pages is unreachable
When externally hosted portal pages become unavailable (say due to network partition) , we would like the controller to just allow client WiFi connectivity (lets assume Radius is working). Is such functionality built-in ? If so, where do we set it up ?
What about if the radius server is also partitioned from the controller ? How do we set it up so the controller allows the clients to just go online .
We are okay with some delay in having the controller realize a network partition, say within 15 seconds.
thanks
Re: Allow WiFi usage when externally hosted splash pages is unreachable
You would need some type of external server to test reachability and then use the API to change access roles.
Tim
Tim Cappalli | Aruba Security
