How do you setup for your Amigopod in redundancy mode? Active/Standby?Active/Active? What's your recommendation?
Good question.
Scanning through the Amigopod Deplyment Guide v3.5 I see the chapter regarding High Availability Services. Have you read this? Gives quite clear details regarding the setup and configuration needed.
Now - would this also need a double set of user licenses?
We don't have Amigopod yet but going to deploy in a month or so. Thanks for giving the tip about the documents in Aruba. I read the High Aval document. It seems like cluster mode will only have one server running and failover to second one if primary down.
yes do i need double set of user license?
No doubling of licensing is needed, only a HA license. Its an Aruba product, but doesn't have the controller licensing hierchy.
Hi, just to confirm that is correct, you dont need to purchase second user licenses for HA appliances, just a comparable model of HW/VM starter kit (the HA plugin is built into all HW/VM appliances
Carlos
