I am having an issue with Android tablets running Android ver 6.0 where the
tablet connects to my 802.1x authenticated SSID, successfully authenticates
according to the auth logs on Clearpass but will not connect to the SSID.
The Tablet says there is an authentication problem. CPPM shows the tablet
as having successfully authenticated and sends the accept message along
with user-role attributes back to the controller as it should. The client
is not in the controller's user table.
I understand this may have something to do with the processing of EAP/TLS
but The SSID in question is using PEAP/MsCHAPv2
Controller OS version 6.4.2.4
CPPM Version 6.5.1.72346
