Android Lollipop: Onboard - Additional DNS entry
I've been doing some testing with Lollipop and it appears that you will need to add an additional DNS entry to your Android netdestination in order for devices to be able to download QuickConnect from the Play Store.
You'll need to add:
*.l.googleusercontent.com
netdestination ND-GOOGLEPLAY
  name android.clients.google.com
  name *.l.googleusercontent.com
Tim Cappalli | Aruba Security
Re: Android Lollipop: Onboard - Additional DNS entry
Why is *.ggpht.com not in there?
I wanted to restrict it down to the least number of entries and it completed the process without the entry. I think that may be used for certain elements of the play store UI which are not used because you are going directly to the application.
Thank you.
Some new developments here. This is my current working setup:
  name *.gvt1.com
  name *.ggpht.com
android.clients.google.com hosts some required elements of the Play store
gvt1 hosts the actual application APK cache
ggpht hosts the application images in play store
Occasional Contributor I
Do you have any updated entries?
