Frequent Contributor II
Android doesn't redirect to Guest Captive portal
Hi:
Can someone remind me where the redirect to a Guest captive portal is setup in CPPM / CPPM Guest?
I'm having a problem where Android users are not able to access the captive portal of the CPPM guest network. (Windows and iOS work fine).
From what I've read on other forums, the problem seems to be that Androids are hard coded to use Google's dns servers, and don't use the one handed out by dhcp.
I need to fix this fast, and the only work around would appear to be setting the redirect to a hard-coded IP address, like https://192.168.100.100/guest/guest_register_login.php
Can someone remind me where this redirect setting is?
Tony
Re: Android doesn't redirect to Guest Captive portal
The redirect is on the controller under Configuration --> Authentication --> L3 Authentication --> Captive Portal Profile
Seth R. Fiermonti
Consulting Systems Engineer - ACCX, ACDX, ACMX
Email: seth@hpe.com
If you found my post helpful, please give kudos
Are you allowing access to Google sites in your ACLs? This can prevent the captive portal.
Also, make sure you are allowing OCSP through.
Tim Cappalli | Aruba Security
Hi Tim:
Can you be more specific on which sites I would need to allow access to?
Also, how to allow OCSP?
When I bring up Chrome on an Android, it reports the problem is a dns lookup.
That seems to make sense, because if I go to a Terminal App on the Android, I see the following:
(I've got ICMP open on this role)
Ping to internal dns servers by IP address: successful
Ping to external URL (eg. msn.com): name resolves successfully
Ping to an internal address by URL (listed in my internal dsn servers): does not resolve successfully
I've seen on another forum where someone was complaining that Android hard-codes Googles's dns servers, regardless of what address they get from dhcp. The testing above would seem to confirm that.
Tony
Is this all Androids that you have or jsut this one?  Is the DNS server hard coded in the network settings?  I just tried one and it worked fine for me - Samsung Galaxy Pro
Seth R. Fiermonti
Email: seth@hpe.com
I've gotten the same result on a few different Androids.
Finding the dns server on an Android isn't particulary easy. The command line ifconfig doesn't do it.
I had to download an app called ifconfig that said I was using the internal dns servers, as I should be. But all indications are that I'm connecting to something external.
I've seen posts that say it's hard coded in a file.
Is there an nslookup equivalent for the Android that would tell me this?
Thanks.
I use an app called "ping & DNS" which is perfect for this sort of troubleshooting.
ACCP, ACCX #817, ACMP, ACMX #294
